Hello,<br /><br />I started work today on my 1954 Chris Craft Express Cruiser. Photos can been seen here - http://pg.photos.yahoo.com/ph/joshs...://pg.photos.yahoo.com/ph/joshsfinn/my_photos <br /><br />All the wood in the boat is strong so I don't need to pull that much apart to get it restored.<br /><br />Today I pulled off that top cabin part which was added on by the previous owner so that I can put back to the way that it's supposed to look.<br /><br />The boat is made out of plywood mostely and some mahogany. <br /><br />The next step is to strip all of the peeling paint off. Not all of the paint is peeling though. The paint on the bottom and under the floor boards (which is red) is not peeling but is sort of chalky when you run your hand across it. And the paint inside the berth is not peeling either. From what I've read on here and other places on the Internet, if it's not peeling - leave it alone and just paint over it after cleaning it with mineral spirits and steel wool. <br /><br />Also, after I strip the paint, should I coat it in something like CPES? The parts that are painted won't take CPES, so is it better to strip all the paint and CPES everything or will I be ok without doing that? <br /><br />Also, does the brand of stripper matter or are they all pretty much the same? I guess they make a spray on kind and a paste/paint on kind - which is better?<br /><br />Thanks for your advice!<br /><br />-Josh
