CrownlineRider92
- Apr 17, 2017
- 14
Looking for some advise what to check next. Below I outlined what I have observed and the troubleshooting steps taken so far. Thanks in advance for any knowledge.
Boat Specs:
1992 Crownline 196BR, 350 Mercruiser, Alpha One Gen 2 Outdrive, Quardrajet Carb
What Happened:
I was pulling a tube this weekend on the lake. Prior to this issue, the boat was running great with no issues. Throttled up to get on plane and the motor shuttered/died almost immediately at 3/4 throttle. Boat started back up with no issues and idle fine. Tried once again and the boat died the same as the first time at 3/4 throttle. The engine did not stubble or bog down before it dies, it just cuts out. If I throttled back quickly, It would stay running.
Third time, I throttled up and once again the engine dies immediately at 3/4 throttle. I left the throttle forward and pulled the cover on the engine hatch and found the shift interrupter switch was pulsing on/off quickly.
I spent about a hour on the lake trying different things I outlined below with no luck resolving the issue. In the end, I ran the boat at lower cursing speed/rpm the rest of the weekend with no issue. Boat seemed to run just fine but still would shut off if I throttled past 3/4 throttle. I was happy it never left me stranded and did not end the weekend early! Now that I am home, I am looking at what to do next to get this issue resolved. Felt like the boat had a governor or rpm limiter I could not pass.
Question:
What would cause the shift interrupter switch linkage pulse on/off like this at 3/4 throttle? Is this even a shift interrupter issue? Would the shift interrupter toggle on if the engine dies? Ignition System issue maybe?
Troubleshooting done so far:
Shift Interrupter Switch:
First thing I did was to disable the shift interrupter switch. I moved the lever arm off the cam which it sat on. Once again, I throttled up and the boat died at the same exact rpm/throttle condition. I started the boat back up and shifted into forward, then tried to shift back into neutral. Because the switch was not cutting ignition, I was unable to shift out of gear. This told me that I effectively disabled the switch.
Shift Cable:
The the lower shift cable was recently replaced (2 years ago). I removed the shift cable from the linkage and it operated with no binding. I then adjusted the shift cable by turning the brass barrel and repeated my test to see if the motor still died at 3/4 throttle. No matter which direction I adjusted the shift cable, the engine would still die at 3/4 throttle.
Fuel System:
Engine does not bog or stubble. If it was starving for fuel, I do not see the engine cutting out as quickly as it did. This rules out fuel system I think.
Ignition System:
At this point, I think it has something to do with the ignition system cause of the consistency of the engine shutting off. My trouble is most components of the Ignition system tend to fail completely when they do.
Items to Check: 1. Cab & Button 2.Coil (Boat runs so has spark, doubt it is bad) 3. Spark Plugs (Check Burn Color) 4. Distributor Sensor (Reading tell me that it either works or doesn't. Once again the boat runs at low rpm) 5. Thunderbolt IX ignition module.
Thanks once again!!
Boat Specs:
What Happened:
Question:
Shift Cable:
Fuel System:
Ignition System:
Thanks once again!!
