ristovski1991
Thread starter- Joined
- May 24, 2018
- 9
Hello everyone i am new to this forum and new to boating. I tried looking through this forum and others to resolve my issue on my outboard. I believe i have a 77 merc 140 tower of power i cannot locate a nameplate anywhere on this motor. I was only able to find a few numbers on the block which are 8527738 and 62301. I suppose one of these is a serial numbe.
Anyway to get back to the problem i am having: with everything hooked up my motor is turning however i have a spark issue. When i do a spark test with a plug unscrewed connected to wire and held against ahe frame i only get one spark. Sometimes i get it when i am switching my ignition from on-off and off-on but no continuous sparking when motor is cranking. I already know my coil and control box are good as i conducted some tests that i found on youtube so i have continous spark when doing those tests. I also conducted a trigger test and i assume i did all those tests right and still the same problem when everything is hooked back up. Im willing to take any advice.
