merkdawg0084
Thread starter- Joined
- Oct 11, 2017
- 573
Hell, I have a 1982 evinrude 7.5 hp. this motor had a piston seized, I got the piston unseized, but unfortunately it only has about 60 psi of compression and the other cylinder has 90. So i found a powerhead on E-bay. Guy says it has good compression. My question is how can I check the compression before I put it all together? Put a nut on the flywheel shaft and turn it with a drill? Thank you
