Hey guys,
I have a 40hp johnson super seahorse (rdsl-23) and Ive had it running almost perfect.
Ive put new coils in and tinkered around with almost everything (rebuilt carb, fuel pump and what not)
So fast forward to yesterday...
Had it running pretty solid for about an hour (in garbage can) and when I put the throttle to idle it would slowly drop down to the point in which it would kill itself. So okay the low speed needs some fine tuning which wasnt a big deal.
After it had stalled itself I figured why not put the generator back on and see it that is working as well in the next run.
put the genny back on and went to start and have no fire. engine cranks and cranks but nothing.
Ive checked the fuel pump (pulled off line from tank to pump no blockage, pulled of line from fuel pump to carb and it shoots fuel 10 ft, on choke you can tell the carb is pulling fuel from the bowl and checked for fuel in the cylinders and they do (took a lighter and they both light up like a rocket))
SO... That tells me the fuel system is working correctly which now leads me to check for spark.
Go to check for spark and have nothing...which does not make any sense as I had it running almost mint before.
anyone have anything they think I should check????
