Duke 64
Duke64
I have a 69 Evinrude Fastwin, 18hp. Would like to install a electric starter. Exactly what is needed to get it done? Also are parts available?
The best / cheapest way is to find a donor motor with all the bits.----A very common request to change the to electric start as folks get older.-----Found one in a dumpster years ago with the electric start.----If the recoil rope is not installed / timed properly they can be hard to pull over !---You need starter bracket and the starter.----Flywheel may have the ring gear already.-----The wiring , solenoid and starter switch are readily available new.----Parts from 1960 to 76 on 18 / 20 / 25 hp motors are essentially what you need.
lindy46
Here's a used starter and bracket for a reasonable price (not my listing):
https://www.ebay.com/itm/OMC-Johnson...-/253627875267
A "new" bracket alone will run over $300. You may also want to place a free want-ad on AOMCI.org - someone may have one for a reasonable price. You can buy a rubber-capped "momentary on" push button starter switch at a tractor supply store, and mount it on the front pan of the motor. They will also have the battery cables and a short cable to run from the solenoid to the starter. You'll also need some 12AWG wire to run from the push button switch to the solenoid.
F_R
That's cheap. Better grab it. Those brackets are getting hard to find.
Duke64
Thanks for the info, need do some investigation, again ,thanks
welcome aboard.
same question was raised yesterday.
the cheapest, easiest, fastest and most fool-proof method of converting your motor from pull-start to electric start is a three step process as follows:
sell your pull start for small pile of cash
take small pile of cash, empty wallet onto it, creating slightly larger pile of cash
take pile of cash and buy a newer electric start motor.
not only is it cheaper, you can do the conversion in a few hours.
Duke64
Thanks for the info ,the flywheel has a ring gear .Ordered part from E-Bay . Will gather remaining items and wait for the package to arrive .
Duke64
Upon reading the article from the Cheesehead, can I leave the pull starter on or should it be removed?
Pull starter bolts to the electric start bracket.----The motor does not have the capacity to charge a battery.---Recoil should be installed for that reason.
