1980 OMC 6 gallon Evinrude Fuel tank
phuffman
Fuel tank is creating too much pressure.
Looks like I need to replace the float unit.
Where/who sells these? Really struggling to find.
Thank.
oldboat1
not understanding. '80 tank would have a vent on the gas cap (would certainly release pressure). Getting build up of pressure from out in the sun? Check bulb and connectors, and make sure the arrow on the bulb is pointed toward the engine.
oldboat1
you mean you have gas coming out of the carb throat when priming, maybe? That might indicate a blocked carb vent.
Vic.S
I think they might not have appeared until 1981
I think phuffman is refering to the older type of tank with a contents gauge
convert
oldboat1
Thanks, Vic. Would presumably loosen the cap to relieve pressure, but maybe more involved.
The old steel tanks are sealed when the hose is NOT attached.----Allows you to put it in the trunk of the car with no fumes.----When hose is plugged in there are 2 wee pins that are pushed in.-----One is a vent valve.---Other one is a valve that lets gas out.----Much better tanks than some modern plastic junk.
F_R
It should be noted that the vent is a one-way vent. It lets air in to replace the fuel drawn out, but does NOT allow air to escape. To comply with laws forbidding emission of fuel vapors.
All of this means that considerable pressure build-up from sitting in the sun can happen. I think there is a safety feature that allows air to escape before something blows up though. Not 100% sure on that feature.
phuffman
Thanks everyone. I will send this to my dad. I think he'll be able to fix the tank IF he can get the parts. It is the "older" style tank as seen in the diagram above left.
Those are great tanks.-------Get the new O-rings and " welch plugs " and it is an easy fix.------They do not vent until the hose is attached to the tank.
SweetD
Here is a great tutorial with pictures and step by step how to replace the o-rings, Welch plugs, etc. I just rebuilt my second tank valve this weekend, easy:
http://www.oddjobmotors.com/tt4_singlelinetanks.htm
I had the unfortunate experience of the old o-rings letting go and the tank self-pumped a few gallons of gas all over my deck!
Dave
jimmbo
Carb vent?
Fuel pouring out of the carb while priming means high fuel level. Float set too high, Float saturated with fuel, dirty or damaged inlet valve
jimmbo
I always considered a tank with pressure a convenience. No need to squeeze the primer bulb after switching tanks.
Rustywrench
Several things to consider here that are more than this man may need to know, but the rest may appreciate. First off a fuel can filled with cool fuel early in the AM and left in the back of a pickup truck in the hot sun can build to 30 lbs of pressure. Discovered this during early VRO day. Easily enough to over come the best carb needle & seats. Also more that enough to power a motor for a long time if the VRO fails (air motor side) & pressure just keeps on supplying raw fuel. F_R & racerone have it right as to why the tank is designed this way. First spills in the back of cars/smells. Then emmisions. Cant have those nasty raw hydrocarbons escaping. Never mind that the plastic tanks grow until they are round & roll all over the boat, junk! IMHO. The pressure is strong enough that over time the back & forth became known as oil canning the tank. Cracks would appear in the bottoms. Just like flexing a piece of steel back & forth till it breaks.
