roscoe
- Oct 30, 2002
- 21,921
Suggest you find and re read those directions to see if they aren't talking about max load. If so, you're right. Partial load is what I'm talking about. This is nothing new, and it's common knowledge. Check into it.
Well, I suggest you find and discard that wives tale.
Every tire retailer says to run ST tires at max pressure.
Do I need to provide 3-4-5 links for you, no.
Tire manufacturers say the same thing.
The last three sets of trailer tires I purchased, ( Karrier, Kenda, and Carlisle) had a sticker on the tire, or accompanying literature with tire that stated to run at max pressure.
And then there are the dozens of members here, and hundreds of tire shops that say the same thing.
While I have seen one (1) tire manufacturer that has a tire load/air pressure chart on their website, it is there to show the decreased capacity of the tire as pressure drops, not to recommend you use lower air pressure.
Loadstar/Kenda:
"Trailer tire manufacturers always recommend running the max air pressure that is specified on the side wall (measured when the tires are cold)."
ETrailer:
"Special trailer tires should be inflated to their maximum air pressure. At the maximum air pressure, the tires will perform and wear best, and get the best gas mileage."
Carlisle:
"Tire Inflation
"Always keep the tire manufacturer's maximum recommended air pressure in all your trailer tires."
– Maintain air pressure at the maximum PSI recommended on the tire sidewall.
Karavan Trailers:
"What tire pressure should I inflate to?
You should always maintain your tires at full pressure. This is indicated by the tire manufacturer on the tire's sidewalls or on the trailer manufacturer's certification label. Always check tire air pressure when the tires are cold."
Yes, this is a seriously contested subject, even here on iboats. Imagine that. Synthetic, solder, crimp.
But not a single person has cited a manufacturer's source that says to lower your air pressure for a lighter load.
While anecdotal evidence and pleas by some to "use common sense" are all nice, they don't change the facts.
Question: Do you know any commercial carriers or professional drivers, that change the air pressure based on their load? 3 pallets of eggs, or a 30,000# coil, the air pressure stays the same.
And if lowering the air pressure is what we are supposed to do, where is this documented?
Where is the online calculator?
Where is the easy to use app for your phone?
As you said, " Check into it. "
endtrans
