You may be wise to look around for a parts motor in your local area. If it has a better Carb you can clean it or put a kit in it and see if you can get it going. If you do, and think the engine may have been submerged, I would run it with a tank of gasoline with a richer oil mixture, (like say 24 to 1) just to get extra lubrication to the bearings. I would also recommend that you run it at slow speed for the first hour. That will also ensure that more of the oil stays in the crankcase.
A parts motor will give you a spare lower unit, coil, drive shaft etc.
If you can't find another carb, free this one up and put in a carb kit. The new floats are no longer made of cork and are in my opinion, better. They are plastic.
Best of luck, these are good, tough old motors.
