how to test coil - 1981 2hp evinrude
so
picked up this non-working motor a while back, hope to bring it back to life and use it on a dinghy. Have a little basic knowledge of outboard maintenance.
after some work, I'm still getting no spark. could it be a bad coil?
things I already did.
1. changed plug
2. changed condenser
3. cleaned coil and condenser contact points.
4. ran continuity test on condenser, coil and spark plug wire, they're ok. but i've been told that although continuity tested ok but it doesnt mean the coil is generating enough voltage.
5. ran compression test, 120.
any idea what to do next? thx
attached photos. (The coil screws have been tightened before I ran spark test.)
boobie
Take the coil into a shop that's got a coil tester or buy a new one.
RCO
Did you clean/polish the breaker points and set to .020?
Crosbyman
https://www.ebay.ca/itm/Ignition-Coi...72.m2749.l2649
what is your ohms reading form plug both to engine frame ground
I would strip the 2hp bare .... you can't expect to run long with that rusty crud floating around the point gap.
brush and clean that mag plate scrape and redo all connections get a set of new points and a new coil clean, set and adjust the point set to .020 .
check the flywheel magnet with a screwdriver... does it pull strongly
p.s. oil that wick
  • Like
Reactions: so
Crosbyman
it depends.... if your existing coil is bad ....yes a new coil will help....... but I don't think we are there yet ..
btw get the coil with low shipping fees no sense in paying double. try the site I gave you
https://www.ebay.ca/itm/Ignition-Co...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
what ohms are you reading booth to frame ground ???... 2nd try
for now just get it to open a bit on the high point of the cam ...sparks should appear and sinc yout not running it on the lake it doesn't matter since the plugs are out .. you can fine tune later
btw ....REPLACE the wick..then oil it a few drops
so
what's frame ground? booth meaning spark plug booth?
what is the wick for? thanks.
yes, flywheel magnet has strong pull. the coil magnet also pulls although not as strong.
Lubricates the cam so that there is minimal wear to the wee block on the points.----Means you only have to adjust points gap once a season.
so
yes! got spark. removed coil, condenser, thoroughly cleaned the plate, lightly sanded all contact points, applied electronic spray cleaner, put things back. seeing sparks.
things to be done:
clean internal fuel tank.
replace fuel line. i wanna use clear fuel line with an inline filter though.
clean the carb.
lube lower unit.
anything else ?
question: how do I remove the carb. looking from below. I only see one bolt holding the frame (see pic) but seems there's another bolt at the air intake but it's really hard to see. any pointers will be appreciated. thx
The carburetor is held onto the intake manifold by 2 nuts on the end of 2 studs.
oldboat1
The tank shut off valve is built with a filter in place. If it's intact, that should be all you need. Probably want to clean the valve anyway.
so
seems like there's only one bolt holding the frame to the body but it's rusted really bad (see pic above). to get to the carb, I need to remove the frame, right?
fuel valve is very stuck, wont budge. already applied lots of pb blaster.
Bonaventure
I personally do not like the little filter that comes with these. Since it is inside the gas tank, it is hard to see whether or not it is plugged. I like to pull the fitting, cut the screen off, replace the fitting and install an inline filter in the rubber fuel line.
You should also think about rinsing out the tank, either with solvent (varsol is OK) or dish soap and hot water with a thorough rinse with the water hose.
Crosbyman
don't paying more for shipping than the item price ..... shop around .. ask a friend for free amazon PRIME rate
by the looks of the motor I would want to run it a bit before emptying my wallet
your impeller may.. still work as well as your carb
carbs usually need a just really good cleaning and air blow job to clean the crud out of small passage . if needles are ok you are all set
check utube movies on how to
the tricky part is the low speed chamber on top but a good blast of carb cleaner in the top needle passage way may do it
if plugged which it might not be anyway
before spending big bucks try to clean the carb real good
  • Like
Reactions: so
Vic.S
The two screws #3 secure the recoil housing
The two screws #15 together with the two screws #4 secure what I assume you are calling "the frame" #2. When that is removed you will be able to remove the carb
  • Like
Reactions: so
Bonaventure
I can still get new parts up here in the wilds of Nova Scotia, check outboard dealers in your area, they may have a carb kit, or impeller or lower unit seals etc. in stock. If you pay a bit more and don't have to get them shipped to you, plus save time it may be worthwhile.
I have 2 of these motors, a "78 Johnson and a '74 Evinrude. Most of the parts work throughout the model years. The big difference is when the change went from the steel gas tank to the plastic one.
