engine starts then won't restart
guyboyajian
I thought I lost this post so I started another one under rudemotor it tells more than i wrote in this post.
I read all of your reply's and want to thank all of you.. I have some answers. I do have spark. I took the plugs out and pulled the cord to start and spark came from each plug. I did a compression test and each plug was 30. I did purchase a manual online and received it yesterday. I read the manual and don't know if I can do this work, but maybe I might have to try with some of your expertise.
I will copy what happened when i bought the motor and then got it into the lake to run it. View attachment 1978 Evinrude 4hp 2 stroke Model 4806E.docx
Compression of 30 psi is too low.----Remove cylinder head .----Possibly a blown head gasket between cylinders.
guyboyajian
Thanks for the reply. Is that something easy to do? Will I need special tools? Should I take it to a motor repair shop? What would that cost if they did it?
Chinewalker
Don't take the head off. If compression was actually 30 psi, the motor would not start at all! More likely an issue with your gauge or method of testing.
Speaking of methods, what is your starting method? Are you using the choke when you're trying to start the motor after its warmed up?
guyboyajian
I also had a mechanic shop bring out their tester they got the same reading around 30. When it's cold, I choke it and then once I almost hear it start I push the choke in a little and get it started. When it was warmed up I would first not choke it and then would choke it a little but I couldn't get it started at all Today I couldn't get it started. I most of pull it 20 times and nothing. The spark plug is getting spark. I used a spark plug tester. The manual says .04 gap, does it need to be exact or should I close or open the gap a little? Would that help? I'm getting frustrated. Thanks for the reply
mikeouel
I had the same problem with my Johnson 10hp. It ended up being the head gasket. It started and ran fine, after some running it lost some power but barely noticeable after turning it off it would not start until it got cold again. Replaced the head gasket and problem fixed. Now its overheating at idle, but that's another thread...
guyboyajian
Thanks, As I told racerone, I will replace head gasket.
