engine starts then won't restart
guyboyajian
I have a 1978 Evinrude 4hp 2 stroke. I get the motor started then I run it for awhile then shut it off. The motor wont start back up.I have to wait for a while, it might or might not start. What could it be?
RCO
First thing you need to figure out is if it is a spark or fuel issue. Bring a spark tester along to see if you have spark when it doesn't start.
Raczekp1------Are the coils under the flywheel on this model or does it have the reliable electronic ignition ?
What is the model # of the motor ?-----You really need to post compression numbers for experienced folks to be able to help YOU.-----Have you installed a new impeller , yes or no ?
F_R
A 1978 4hp has CDI ignition. But that doesn't rule out an ignition problem, the most common cause of hard re-start. It might have a bad driver coil, for instance. Could also be other causes. Bottom line, checking for spark when the problem rears up was good advice.
guyboyajian
Yes a newimpellar was installed. Thanks for the reply
guyboyajian
I bought it used and the seller said it had good compression. I'm going to take it to a repair shop to make sure. Thanks
guyboyajian
I'm sorry I forgot to answer your other question. Model #4806E
oldboat1
Go to an auto parts store and buy an adjustable spark tester (open air). Set it to about 3/8” or so for testing — remove both plugs, and make sure the tester has a good ground on the powerhead. Additionally, see if you can rent or borrow a compression tester — screw-in style with a release button on the gauge. Again, test with both plugs removed. With the tester installed in one of the plug holes, pull the starter rope 3 or 4 times until you see the gauge needle stop moving. Note the reading, and repeat with the second cylinder.
Post results. It’s possible to find good spark and compression in the driveway, but get restart problems on the water. Check the spark at that point to see if there is no spark at one or both cylinders. Additionally, I would take its temperature — test the top of the head with the heel of your hand. If too hot to touch, it’s overheating. (should run somewhere around 140F — able to hold your hand on the top of the head for at least a few seconds).
guyboyajian
I will try this and will post afterwards. Thanks I appreciate everyones help to this problem.
