Help - Johnson 7.5 Is Slow
Gatorbait351
70s Johnson seahorses 7.5 on a 14 foot aluminium John boat. Runs good but won't go over 5 mph. Carb checked doing what it's supposed to be anything else someone can think of
Could be running on one cylinder.----Check for STRONG spark on both leads .---Or pull one lead of at a time when motor is idling and report what happens.---Test compression too.----Water pump impeller replaced recently ?
F_R
Universal symptom of running on one. Do what racer suggested. Also, don't ignore it is possible it is only a bad spark plug.
Gatorbait351
It's an 80s I had no clue took a quick guess on it. My first motor for a boat no experience on working on thim
hardwater fisherman
I had to ask because there is quite a difference in the early 7.5 and the later ones. Sounds like it not running on the bottom. If it has two ignition coils you can switch them and see if the problem follows.
??----They made a 7.5 in 1980 / 81 / 82 ------Then an 8 hp and 6 hp starting in 83 I think .----All the same motors.-----Really nice runners too.
tomhath
Master Chief Petty Officer
Before spending any money heed the advice that it might just be the spark plug. Try swapping them and see if it still only runs on the top cylinder.
F_R
One driver coil and one sensor fire both cylinders. That leaves power pack, spark coil, wires, and spark plug. ----OR we are assuming too much. Might have serious engine trouble on the missing cylinder. That's why racer suggested checking spark and compression to try to narrow it down.
Gatorbait351
Switched coils and would not run at all. Put Thom back the way they were and noticed the bottom coil has a little stream of electricity running from the top to the side were it's bolted on
F_R
Well the one that is arcing out is no good, for sure. But we gotta wonder why the good one didn't work in it's place. Check compression yet?
Gatorbait351
I noticed there was a yellow wire on both coils do u think the coils could only go in one spot. Cuz when I switched coils yellow wires weren't were the wires hooked up
Chinewalker
Coils should have a black wire and an orange wire. The black wire is ground. Orange goes to the power pack. When you switched coils, you swapped the orange wires in their plug, correct?
