- Mar 8, 2009
- 44,290
With the muffs and water on, engine off, quite a bit of the water is coming out where the lower meets the upper. There was no gasket and I'm assuming this would be normal?
This is not normal and your motor is not getting much if any water. There is a tube which connects the lower with the upper and has seals, somewhere these two are no connected together. Need to remove the drive and pull it back apart
