Timing
Joe86
i have a 1981 Evinrude 70hp (e70elcim)..changed out the timer base and runs good in the driveway.. question is what should the ideal degree be and the wot ideal be?? I have a timer light and want it to be on point.. Can’t find it online and have no manual ..thanks for any input
F_R
MAYBE, just maybe, somebody here will have the specs (I don't) and post them for you. But without the correct manual specific to your motor, it is impossible to know. The procedure can change about as often as we change socks. A correct service manual will save you time and money---and possibly a motor.
Joe86
I’m hoping someone does on here..that’s why I gave the year model and hp...I’ve called few Johnson shops in town and they haven’t been helpful to tell me the degree but I can bring it to them and pay them to time it for me..I have the tools and knowledge to do it myself but I just don’t know the specs..so maybe I’ll get lucky here
jimmbo
What I was able to find. 19 degree BTDC max advance, and TDC being the throttle pickup spec
Joe86
Thanks guys..I’m take the boat out tomorrow and see where the timing is at in WOT and make the adjustment if it’s off
Joe86
I know of two ways to time it..take it on the water and full throttle it or ground the spark plugs..ground the safety start and put it in full throttle and turn the key..not sure if one of those are the joe reeves methods
Joe Reeves
(Timing At Cranking Speed 4°)
(J. Reeves)
NOTE: If your engine has the "Fast Start" feature", you must disconnect/eliminate that feature in order to use the following method. The "Fast Start" automatically advances the spark electronically when the engine first starts, dropping it to normal when the engine reaches a certain temperature.
The full spark advance can be adjusted at cranking speed,"without" have the engine running as follows.
To set the timing on that engine, have the s/plugs out, and have the throttle at full, set that timer base under the flywheel tight against the rubber stop on the end of the full spark timer advance stop screw (wire it against that stop if necessary).
Rig up a spark tester on the #1 cylinder plug wire. Hook up the timing light to the #1 plug wire. Crank the engine over and set the spark advance to 4° less than what the engine calls for.
It's a good idea to ground the other plug wires to avoid sparks that could ignite fuel that may shoot out of the plug holes. I've personally never grounded them out and have never encountered a problem but it could happen.
I don't know the full spark advance setting your engine calls for, but to pick a figure, say your engine calls for 28°, set the timing at 24°. The reasoning for the 4° difference is that when the engine is actually running, due to the nature of the solid state ignition components, the engine gains the extra 4°.
If you set the engine to its true setting at cranking speed, when running it will advance beyond its limit by 4° which will set up pre-ignition causing guaranteed piston damage! You don't want that to take place.
No need to be concerned about the idle timing as that will take care of itself. The main concern is the full advance setting.
A fellow member from one of the various marine forums suggested having water supplied to the water pump (flushette or barrel) simply to provide lubrication to impeller. A worthwhile suggestion I thought, and entered here.
Be sure to use your own engines spark advance settings, not the one I picked out of the air here in my notes.
