WOT timing
bgbsshntr
I have had the power head to my 1999 Johnson replaced, and boy did the guy screw things up. I have just a couple more things to do to it and hopefully it will haul butt again. Here is my question, I keep hearing about Joe Reeves method of timing but can't find it anywhere. Exactly how is this done, and how is quick start disabled. I have heard -4 degrees but quick start disconnected????? Timing is what detonated my old power head and have to much money wrapped up in this one to not make sure all is good.
Faztbullet
Are you sure it was timing??? 2 things on these models cause pre-ignition...1)bad flywheel hub..2)bad pack..
bgbsshntr
Yes the stator melted onto the timer base and glued the timer base. The moron that replaced the power head played with the timing, then told me he could not figure it out. I started reading and checked it over and found it out. I told him and he said he wondered why the tb was hard to move, and he just left the mounting screws loose. I and a friend have gone over the other stuff. I am replacing the tb and want to make sure of the timing but am to fat and old to be hanging on trying to read a timing light at 60 mph
Joe Reeves
And you got both figured out to a "T"... Good for you!
Mohawkmtrs
Joe:
I just went to the sticky and your procedure is not there anymore.
bgbsshntr
The one thing I am not sure of, do all the spark plugs get removed for the timing procedure. I made a 6 cylinder spark plug tester to plug the wires into. So if all the plugs are supposed to be out I can plug all the wires into the tester.
bgbsshntr
And yes I was pretty proud of myself. I read what seemed like hundreds of posts here and especially if you had replies in them Mr Reeves. The one most important thing I learned in here is that, your words are gold. You have helped me more than you even can imagine. I have learned way more than I wanted to know about my motor. I can work on cars and houses but knew very little about 2 strokes. I now could have swapped the power head myself. By the way that wasn't the only thing he screwed up that I had to research and fix.
Joe Reeves
Yes you want all of the spark plugs removed so that you can obtain the highest cranking speed. The engine must crank over at least 300 rpm in order for the stator to energize the powerpack.
It's a good idea to have the sparking unit out of the way of whatever fuel may be blowing out of the spark plug holes. One day, I didn't for some unknown reason... it was rather exciting there for a few minutes!:eek:
bgbsshntr
Thank you, you have made me a happy camper lol. So this is what I have pieced together from different posts. Remove all the spark plugs... Hook wires to tester..... disable fast start.....wire tie timer base to stop.....crank motor over on fully charged battery.....set timing at -4 degrees at what it says....
Do I also need to open the throttle up?
bgbsshntr
And yes for some reason, this procedure, I can not find the whole thing. I have pulled small bits from other posts, and just trying to put the whole puzzle together
Joe Reeves
Sounds good to me... however, no need to bother with the throttle as far as opening the butterflies... no doubt you'll possibly have to move it some to get the timer-base where you want it though.
bgbsshntr
Thank you sir. We have it marked on the calendar for March 17. We are gonna go over the whole thing from top to bottom. We are gonna start off with another compression check, Sonic clean the carbs, check link and sync, replace the timer base, then set the wot timing. Then the maintenance stuff, replace the water separator filter I added, and lower unit fluid replacement. If all goes well I will be fishing tournaments from my own boat again thanks to you. I can't express how much you sharing your knowledge is so much appreciated.
bgbsshntr
Just as a side note, I was at the point I was just going to drop it off at a big name shop here in Ohio. My first question to them was do you have a test tank to set the timing. He said no and they can't do it till spring when the ice is off. So ask how do you do it. They said on the trailer backed in. I asked that did not sound good at 5000 rpms, and said we do it at 3000 rpms it doesn't have to be 5000 and yelled at me when I said that is what the manual says. This is why I am doing my own work now. No this isn't the shop that replaced the power head.
Joe Reeves
Joe, how are you doing, haven`t been here for a while.
Hey Clayton... good to hear from you again, hoping your problems have all faded away. Things are good with me right now... a little bumpy back in 2016... cancer bug, bladder and prostrate removal... BUT... that's in the past and that's where I leave it. Will be 86 this August 6th, feel like I'm 38 and plan on sticking around until I'm about 122.
jimmbo
They probably do it at 3 grand as the engine under load, will have the timing fully advanced mechanically at 3000. It doesn't take into account any timing variance the switchbox adds/retards as the rpms increase. A lot mechanics set the timing without even running the engine
