My Evinrude. 1967 6hp fisherman
URELady
HELLO again.....had my "baby" running strong and sweet.....still running sweet, but had her out of the water for a few...single digits days.....dropped her in yesterday.,. Heard unusual noise....psst, psst, psst......water....seem to be shooting out under carburator ...checked all gaskets...touched, smelled,...seems to be from intake...no oily feel, no odor, never got warm..,
plenty of water coming out the " peehole" exhaust, just a steady psst, psst, psst....of water squirting inside the engine cover from underneath the front of my engine.....Any advice or information appreciated....I'm a DYI type of gal...took me 6months to get her back to herself after last Marine Repair shop mechanic....So....
Joe Reeves
You state: "seem to be shooting out under carburetor" (water)...... Inside or outside of the hood pan?
Is it the wee hose that goes from the bottom of the block to the top of the block ??---Oil recirculation line.-It might be split.
oldboat1
freeze plug popped open, maybe (domed silver plugs, though sometimes flat) -- closest would be on the side of the powerhead, I think, but water could be squirting forward.
URELady
Thank you for your replies, I'm afraid I cannot see where the water is coming from, seems to be underneath the power head, I can just barely get my pinkie under the carburator, but that's where the "spurt" seems to come from, I have the boat floating on the dock so I'll need to take a light and some tools to investigate further...I emailed Leroy...from Leroy's Ramblings, I have several manuals downloaded, but none show the path of the water very well, but I will definitely check the freeze plugs! I don't believe I have an oil recirculation line since my old outboard has gas/ oil mix ....but I'll see if there is a small hose...I know newer models have a water indicator line, but mine doesn't.
F_R
There should be no water in that oil line. If there is, you are in big trouble because water in there will destroy the powerhead. I'd rather suspect the powerhead - to - exhaust housing gasket is leaking. That would be the only place toward the front that has water in it.
Crosbyman
did this issue just happen after the "single digit days....? could freezing be an issue ?
was the ph worked on (removed & reinstalled with proper gasket) ? any bolts left out ? bolts all torqued ok ?
hard to peek under th carb ? small cameras are getting cheaper and cheaper ..I even used mine to find a leak on the main house drain...inside a wall cavity !
this model was going for $100 recently and is probably a lot cheaper in the US
http://www.canadiantire.ca/fr/pdp/maximum-lcd-inspection-camera-4-3-in-0574638p.html#srp
URELady
Racerone/.82rude.....do you have any diagrams I did not see a wee hose but...this leak is not oil...just clear cold water...no oily feel smell or taste or oil or gas
Headed to dock now...going to try to get a picture....freezing could definitely be an issue...it's sat in the water iced in and not froze, but this year..prior to the freeze we had other weather issues...flash flood warnings,..I pulled it up on the bank with the engine tipped up, and left it that way! My Bad!!!I
Crosbyman
should have been drained vertically !!! I hope it did not crack ..
if it did ... maybe that stuff for pugging radiator leaks could help ????
It should not be hard to find / pinpoint a leak on this simple little motor.-----The story on what happened seems to change.
URELady
Racerone...you might have misunderstood....the boat normally sat in the water all year, but this year was different....and it wasn't left in or trailered....I pulled it up on the bank with the engine tipped forward/up....and didn't have it down to drain!!! Anyway...I do believe some water froze somewhere and cracked something...(that couldn't be more cryptic if I tried)... lol
F_R
As I said, there is no water in the front half of the powerhead to freeze. Of course it could be leaking in the rear half and squirting forward. We have to rely on your local eyeball inspection.
F_R
OK, so I just went out and looked at a powerhead, off the exhaust housing, and let me modify my statement. There is a channel forward of the lower main bearing. Maybe water flows through that channel to cool the bearing. I honestly do not know, and I don't have the exhaust housing to look at. Anyhow, I can imagine water laying in that channel while tilted and possible freezing ??? Bottom line is you would have to pull the powerhead to inspect it. Otherwise, we can guess all day.
BTW, they don't freeze where I work and play.
URELady
I pulled a diagram from Leroy's Ramblings and tried to add an arrow pointing to my leak area... the pictures I took were mostly useless, (it's way too tight under that tiny engine cover for my camera) but anyone familiar with this motor should able to recognize the fuel line going into the carburetor and the pencil (red and white) pointing underneath...looks like I may have to pull the "power head"...(block)...that kinda scares me!
Yes there is a channel that can trap water under the block and at the front.-----Nothing too hard about removing the powerhead at all.---OK---I guess I did the first one of those in 1968 or so and have a bunch of them in surgery at this time !!
URELady
we do not have red ants, african bees, kid grabbing alligators ... just mosquitoes, black lies, skin grabbing deer flies and noseeums
https://www.youtube.com/watch?v=f389hIxZAOc
Well, here I'm libel to to have a combination of it all...one Christmas it was 74* and one year 6" of snow.....we do the noseeums, ticks, chiggers, mosquitoes, sting flies, Cow.Killer Ant/Wasp, (non flying Wasp looks like a 1"long, bright red & black velvet Ant!) Ok and river otters, snakes, humongous catfish...and don't forget GATORBEAVER!
URELady
As I stated I've pulled the flywheel...replaced the tiny little fuel pump, and pulled the carburetor twice but....any tips, diagrams etc would help!
