Hot light and alarm sounding soon after starting
MikeSA
Hi
i have a 2006 Johnsonn 115 that intermittently sounds an alarm and shows the HOT light on the dashboard only a few seconds after starting.
if I switch the engine off and wait a minute or less, sometimes when I restart it doesn't sound again but often it does.
the oil resevoir is about 3/4 and the bulb is pumped firm.
the tell-tale stream out the motor is strong.
it seems unlikely that the engine is overheating after only a minute or three of running.
could anyone assist with pointing me in the right direction please?
I must admit, my very first boat with a fairly simple 80 Mariner on was fairly easy to work on.
By the time I got to a 200 Mariner with fuel injection, I kind of figured it was a bit beyond me.
I'm now sitting in a small seaside town and the one local mechanic doesn't seem to be interested or know what the issue is and the other one seems to be away, so I'm either going to have to fix this or stay shore bound for the holiday.
jbuote
I'm sure somebody with much more experience than I (I'm still fairly new to boating) will be able to shed more light, but as an initial thought to determine if overheating or not...
Try using melt sticks or better yet a temperature gun if you have access to one..
See if it's really running hot. Let us know the temp readings of each head/cylinder if at all possible with these methods (best methods I think....)
If neither of the above are available, a general rule of thumb that I think would also apply to your engine, is that you should be able to hold your hand on the heads...
It'll be warm of course, but if it's too hot to touch, and you have to pull your hand away, then it's overheating..
Maybe try quickly touching the heads when the alarm sounds.. If not too hot, try holding hand a little longer...
The goal would be to start with quick touches (so you don't get burnt if it's overheating), and then progress with slightly longer touches to see how hot it feels..
One head could be simply warm to touch, but the other could be too hot to touch...
Let us know...
No, this will not tell you actual facts, but it should give you an idea if it's truly overheating or not...
Tell-Tale can show perfect water flow, but a LOT of tell tales are first to get water from the impeller/water pump, and then it continues on to the engine, so there could still be some blockage, stuck thermostat etc. that could prevent proper cooling to the heads and engine even when the tell tale seems fine.. It's usually just an indicator that the water pump is working.
Doesn't necessarily tell you the cooling is working properly..
Maybe report back with those results of the hand test and that'll only help the experienced folks here to have more info to help you with...
I apologize if you already knew all the above, but hopefully it's a place to start?
Hope it helps...
Bosunsmate
Pull your head temp sensor and see if its a fault with that or in the circuirty, a few secs isnt enough to get a motor hot from cold to sound an alarm in my opinion (so long as you mean like 10 secs max)
What small seaside town is this, it sounds like mine
jbuote
I certainly defer to Bosunsmate and others..
It was just this line from the original post that made me think it'd be a good idea to see if really overheating or not..
While of course, the real issue should be identified, I was just thinking... What can be done to figure out if the rest of OP's holiday is with boating, or is shorebound..
The overheat alarm could very well be a shorted wire (intermittent perhaps), circuitry, faulty sensor etc...
With an overheat alarm though, my first thought would be to confirm if overheating or not, since it could be very damaging if it is.. If not, then look at other reasons, or if satisfied it's a false alarm, can I continue for a few days with my holiday even if I stick closer to shore "Just in Case"...
I leave you in the very capable hands of Bosunsmate and others..
Just wanted to explain why I commented..
Going to follow along to see how you make out though... :D
MikeSA
What motor do you have? A model # would be nice.
My apologies!
The model no. Is J115PLSDA, so US 115 2006 model with power steering and oil injection.
Huge thanks for all the advice, it's most appreciated!
i looked at the cabling, the engine has done a total of 56 hours, and the motor looks close to brand new under the cover, cables all look in fine fettle, so I imagine it might either be a blockage in the head and no water going through at all (seems unlikely as I'd expect the motor to be very metallic sounding - I once had a Ski-Nautique that the mechanic ran without water so the impeller burnt out and from an audiophonic perspective that was very obvious that water wasn't getting to the engine).
I imagine it might be a stuck sensor or something considering the very low hours and thus the likelihood that the boat has stood unused for long periods of time (also might be the cause of any blockage too).
To answer the location question, it's Kenton-on-Sea in the Eastern Cape in South Africa, a small town with a population of 2000 off season and 20000 in season.
its not commercial, no hotel allowed and no fast food franchises allowed either.
there are two large navigable rivers on either side of the town (about 1km apart), on which you can fish and ski for many kilometers, so plenty of room for everyone and most boaters are polite and considerate to both fishermen and skiers.
there are also two lagoons for littlies, and several beaches that are ideal for different age groups.
ive been coming here for close on 45 years and we have a holiday house here, so we come down at least once, sometimes twice a year.
jimmbo
I too suspect one of the temp sensors is bad, or a wire(s) going to them is grounding
Motors that sit for long periods of time need oil injection tested / verified.---I suggest mixing oil in with gas until you verify oil consumption from the on board oil tank.
