bedliners
marksmith
Will the truck bedliners adhere to fiberglass? Would that make a good floor surface? Just brainstormin.
JasonJ
Re: bedliners
If the surface is prepped right, it should. By prepped right I mean a good scuffing up with 60 or 80 grit sandpaper and a thorough wipedown with acetone to remove any dirt and sanding residue. Prep is the key, any of the do-it-yourself bedliners should get the job done.
glass from the past
Re: bedliners
Hey Kookaneeking, nice to see someone from around here on the forum, <br /><br />Last year at the Seattle boat show LineX had a booth setup and there brochures have pics of the inside of boats, just like you are talking about. I been thinking about trying a roll on beliner like your talking about<br /><br />Where you fish at anyway?
marksmith
Re: bedliners
I fish the sound, kokanee lakes, and amy water that holds bass. I used a somokercraft alluminum for salt water and kinda miss the easy care of the thing. I had to sell and later bought this project of mine. wood can be a pain.
ShawnQ
Re: bedliners
http://www.nonslipcoating.com <br /><br />That's Durabak's website, and that's what I am going with.<br /><br />I am doing the interior of my 19ft Blue Wave Center Console Bay boat.<br /><br />If you can wait about 7-10days, I will show you pics and give an initial opinion on it once I get it applied.<br /><br />I am waiting for it to arrive, and in the meantime prepping my boat.<br /><br />Take care<br />shawn
marksmith
Re: bedliners
Thanks shawn Q I've got plenty other jobs to do on the boat I'll wait for your results.
glass from the past
Re: bedliners
Amen to the projects, I got about 50 things to do on the boat and so little time (March already?). I wanna see how your coating turns out, I just put in a casting deck on my boat and need somthing to cover it in. Let us know on the pics.<br /><br />Kokaneeking: Where is a nice spot around the sound to get into some Bass ? I been hitting lake Sawyer with some success, but I don't know anywhere else to go
wallbanger2
Re: bedliners
Wow, Durabak looks like the ideal no-maintenence product for deck paint. I'll be interested to see how ShawnQ's deck comes out and how hard it was to apply.
JasonJ
Re: bedliners
I actually would like to get ahold of some Durabak to apply to the rocker panel areas of my truck, the paint is getting chipped up (it is a new paint job). I want to get white to blend with the paint, but I do not need a gallon of it. I saw on their site that they only sold it in gallons, but does anyone know if it is available in smaller amounts, or if there is a similar product that I can get in white that will do the trick?
ob15
Re: bedliners
A lot of people have use the bedliner for inside their boats. It looks good.
marksmith
Re: bedliners
Glass from the past, Try Washington, Samamish,and American lakes for smallies.
Bert1
Re: bedliners
Has anyone tried to use the roll-on bedliner material as a keelguard on a fiberglass boat? What they sell here comes in a can and is applied with a small paint roller once the surface is prepped. (sanding and cleaning with acetone). Thanks
LubeDude
Re: bedliners
I can only say that the stuff is really slick when its wet, but then boats never get wet! :eek:
glass from the past
Re: bedliners
Cereal Dude,<br /><br />Is there an advantage to using products like Durabak versus the roll on bedliner? I fish on the sound a lot in my boat and the last thing I want to do is take a spill (or a swim) when it's choppy. What do you think is ideal, carpet, pergo, etc.?
JasonJ
Re: bedliners
Glass, I used Evercoat No Skid on my boat. Great traction, holds up well, you can get it in different colors, easy to apply, about $40 a gallon. It is intended for marine use, specifically floors and what-not.
heatherjoy
Re: bedliners
Is the Durabak bedliner a good anti skid paint that will hide minor imperfections?<br /><br />In other words, does it leave a consistant coat? <br /><br />JasonJ- does the evercote hide imperfections well? Does it leave a nice consistant "pattern" if you will?<br /><br />Thanks for the replys.
JasonJ
Re: bedliners
The evercoat goes on in at least two coats. The first coat sort of hides imperfections, but the second coat really fills things in and hides everything. I actually applied mine in a pattern using a brush, it pretty much stays as you apply it, so it doesn't really even out. You could try applying with a roller, but the brush works better in my opinion. I am sure a person could make it look even if they wanted to, but I wanted a pattern.
glass from the past
Re: bedliners
Well the evercoat doesn't sound like a bad deal for the price, I thought it was much more. The roll on bed liner stuff is like $25 bucks a can anyway, for a few bucks more why not go to evercoat. Thanks for all the replys, one more question though.<br /><br />Do you think one gallon would be enough to do the floor and sides on a 15 foot bow rider, or is more needed?
coachmup
Re: bedliners
JasonJ<br /><br />I went to evercoats website but it didn't say anything about a non-skid product. Where can I find it?
