59 Evinrude water pump impellers
Sporgo@gmail.com
Anyone have a trusted source for quality water pump impellers? I recently ordered one offline for my 1959 18hp under a Sierra number but what I recieved was unbranded and likely chinese rubbish. The end result was the impeller failed while still testing the motor in a barrel. A little frustrating to say the least.
How high was the water in the barrel ?---Was it 6" above the pump , yes or no.---Most quality outboard shops / BRP dealers will have the factory part in stock !!
Sporgo@gmail.com
The water level was higher than necessary. It wasnt run dry if thats what you are thinking. The rubber just basically disentegrated from what I can tell. Some of the fins broke off and the center was loose from the rest. Maybe a bad batch of urethane or whatever these are cast from.
There is only one marine store local to me and they are not good for parts inventory.
F_R
You are standing in iboats' parts store. You can both OEM and aftermarket impellers right here.
