Not sure it will apply to your motor BUT.
I had similar experience recently but slightly higher RPM....probably 1500-2500....Idled great, then when push on the gas it would just limp until a certain range and voila would act right.
My issue was the plug wires...I used a blue Sierra wire from Amazon, which appears to be a resistance style wire...went back to solid copper wire it was instantly right as rain.
So I'll have to ask what has changed?
If you didn't have the symptom right after you changed them there is little chance that they are the issue now...there is a chance...but very slim...my issue and fix was immediateYes I did change them to sierra couple years ago Thanks I have to look into that.
Compression test !!!!!! These models bad about locating pin migration......
