Head and Prop rated hp
thatone123
Banned
I know in the 80's Japan was exporting outboards here that were rated in hp at the prop whereas US outboards were rated at the powerhead. Would that mean that the old 18', and the 1974 on up 15's were not quite the power stated on the cowling? I know OMC increased the bore and stroke on the later model 15's in the late 80's/early 90's. Anyone know if it was because the Asian outboards were rated at the prop and more powerful?
flyingscott
yes the older outboards were powerhead rated motors a 1974 is probably prop-rated 12-13 hp. You can put the newer exhaust tuner from a 1984 model on your motor to get another couple of hp. The 74-92 15 hp motors had improvements done over the years to keep up with newer designs. The Japanese motors came into the country around 1984 some like suzuki were earlier. But Evinrude did not increase the displacement until several yrs after that happend. Like everything else it became an outdated design and changes were needed to make it competitive. Remember Mercury came out with a loop charged 15 Cid motor in 1986. The 13 cid Evinrude was a great design that lasted almost 20 yrs.
thatone123
Banned
Very interesting. Do you think with the 1986 Mercury loop charging, the Merc had more power? I have worked on a lot of these throttle shift mercs, but never bothered to run one, except a few times and it seemed they did not have the torque of the OMC. Mercs of this size usually have smaller displacement than the OMC...right? Also those Mercs have a really strange and finicky choke set-up.
Chinewalker
Horsepower is horsepower. The industry as a whole went to prop-rated about 1985. It affect the larger motors more than the smaller ones, as the industry also has a built-in fudge-factor on their ratings of (I think) 10%. A 10% variance on a 15hp is only 1.5 horsepower, so it's not likely the Evinrude or Johnson bothered re-rating their 15s between 1984 and 1985 to accommodate the changes. They did, however, rebadge the 35 to a 30, the 140 crossflow to a 115, and so forth. Some motors didn't change much and didn't get rebadged. Many did. We run both the Merc 15s and OMC 15s in our racing classes and both have good power, but different characteristics. The 15 OMC racing motor has been around since the mid-1980s, while the Merc 15 racing motor has only been used since the late 1990s. Much more development has gone into getting the OMCs to really sing. They're still figuring out how to get the Mercs to really go. Some guys have got them really singing well, but they're not generally sharing their secrets...
flyingscott
The merc was a 15 cid block compared to the OMC 13 cid block. The merc had a primer set-up not a choke that I thought worked very well. The merc was a good running motor with good power. But for some reason Merc put a wimpy lower unit on those motors that tended to fail. My motor of choice in those yrs is the OMC 15. Parts are easy to find and they made a boat load of them. They were both good reliable motors but the lower unit issues on the merc puts the OMC first.
thatone123
Banned
Chine, That is great news to here about the OMC 15 "racing motor". This must be the one that went to 7000 rpm. I have asked many about this and all said they never heard of 7000 rpm. I noticed those 80's 15's were used a lot on the small hydroplanes. OMC must have made a batch just for racing?
thatone123
Banned
Flying Scott, Funny you should say that about the Merc lower-unit as I always thought the 15 OMC had a unnecessary overbuilt lower unit since I want light-weight, which the Merc 15 is 3 pounds lighter. That is a huge lower unit on the 15, more stout than any other make by far. I do put the OMC 15's under a lot a strain/loads and they do hold up though.
You have not seen any of the 15 ? motors with the racing lower unit ??
flyingscott
I would consider the OMC lower unit robust and reliable a good design. I would say just the opposite about the Merc lower. The 7000 rpm rpm limit was put on all the production 15 hp motors in the late 80s. Had nothing to do with racing.
thatone123
Banned
That is great...the photos of the racing motors. Have seen some of those but never the OMC 15. If not 7000 rpm, what did make these racing motors out of the box besides the lower unit, which is really cool...wish I was younger! lol
Chinewalker
Only other differences were a full butterfly in the carb, and linkage for the bowden wire throttle hookup. Power heads were bone stock fishing motor power heads.
