1990 70hp VRO tachometer
89 Bonito
I recently purchased a new sierra tachometer for my Johnson as it did not have one installed when I got it, I've tried to trouble shoot it but my patience has come to its end and I'm giving to the hopes the interwebs can help. When I go to crank the motor the tachometer reads rpms ( kind of jumps around 600-1000 rpms) but the moment the motor starts it drops down to 0 and doesn't read, I've tried changing the pulse setting and some other oddball stuff, but alas, the same result. Any pointers to get me going in the right direction is appreciated
89 Bonito
What's the voltage on the gray lead that feeds the tach ??
All readings were taken with a fluke 87 true RMS with the battery switch on and no other accessories on, the battery read 12.18 volts post to post. Also this is how my tach was hooked up, ground to black, ignition to purple, send to gray.
Gray = 12.22v when key is on or when the motor is running
Purple = 12.22v when key is on or when motor is running, also reads 1v when the key is on the off the position
Purple to gray reads -.380v (had the probes switched around)
Gray to purple reads .380v
Key is off
Gray to black =12.18
Purple to black = 1.020v
Key is on, motor is off
Gray to black= 12.18v
Purple to black =12.18
Also there is a 3 pin connector in the motor that looks very similar to the one for the tach harness, it has brown black and gray wire but it isn't hooked up to anything, there's also one standalone brown wire that isn't hooked, are these components for the VRO pump, mines premix btw
