Evinrude identification
Delta422
Looking for any info I can find about this motor I picked up .it is evinrude and I have a number 4348 -01525 I guess it is serial numbe any thing would be help full year ,hp thank you
F_R
4348 is the model #. The rest is the serial number. It is a 1940 Sportsman 2hp.
F_R
1 Cylinder, 1-3/4" bore x 1-35/64" stroke, 3-3/4" cu in displacement. 2hp @3500 RPM. 7" x 6" two blade weedless prop. Breaker point gap .020". Spark plug Champion H-10C gapped .025". Shear pin 3/16" x 15/16" aluminum. Weight 23-1/2 lbs. Oil 1/3 pint per gallon. Lower unit gets outboard motor gear grease, now obsolete. Use Lubriplate 105 Motor Assembly grease from NAPA or corn head grease from John Deere. Centrifugal water pump and Simplex recoil starter.
jimmbo
1/3 pint per gallon? I thought it would be 1/2 pint per gallon on an engine that old
Delta422
Does anyone know if there is parts available for this motor and where
F_R
Us guys that mess with these old things just cope. It depends on just what part you need. One good source is the classified ads forum at the Antique Outboard Club's website www.aomci.org The ad is free, and there is lots of stuff in member's stash.
F_R
I just double checked. 1/3 pint per gallon, per Evinrude-published chart.
F_R
What I said, aomci.org
You might find a copy, certainly nothing new.
