furpy
Thread starter- Joined
- Oct 6, 2017
- 10
Hello there...I have a 2 hp Johnson that I am rebuilding.....new coil.....carb rebuild kit....and new packing on the lean rich high low needle valves...gapped the points at .020....my problem is...it gets too much gas.....I open it up full throttle and it just chugs....I close both needle valves all the way and still gets too much gas...what?s going on?...When I close the fuel line, it will finally start to run fast and then die from fuel starvation.....put new float....needle and seat.....new packing on the needle valves....the packing was two rings of what looks like cork or something...and the one washer that was some kind of plastic....the needle valves looked like they were in good shape....
