Fuel Gauge Sender Replacement
FreeBeeTony
The sender for my fuel gauge needs replacement. The boat is a '78 20' Grady White Gulfstream w/ Mercruiser 165 IL6. The access hole does not seem to be big enough for the job. I guess I will have to remove the piece of floor over the tank? The previous owner installed something over the floor in the cockpit, I forget what you call this stuff. Is there anything special I need to know about the sender replacement?
D
DJ
Guest
Re: Fuel Gauge Sender Replacement
FBT,<br /><br />It's a relatively simple job. The senders are pretty much universal. Make sure you replace the gasket.<br /><br />As far as access goes. I would cut a hole, the size of a deck plate that you can install. That way you'll have good access anytime you want.<br /><br />Good deck plates are pretty inexpensive.
FreeBeeTony
Thanks djohns19, that's a great idea! I didn't think of that.......probably saved me alot of work!
D
DJ
Guest
FBT,<br /><br />If you do not already have them, they are handy to install where the fill/vent and outlet hoses attach to the tank also.<br /><br />Good luck.
