Blue Drain Plugs
Capt. Alec
Hello everyone,
I have a 33ft 2008 sea ray Sundancer, I'm seeking help because on my motors (8.1 mercrusers) the blue freeze plug keeps breaking. This is my third season changing one cause each season a plug has broke I'm asking for help because I don't know what would cause them to keep breaking, once its broken what's the best way to get it out and lastly what I can do to prevent them from breaking In the future. I'd appreciate the help thank you.
tpenfield
:welcome:
​Do you mean the blue drain plugs that are unscrewed to drain various parts of the engine?
​Yes, they seem to break easily. You should probably buy a supply of them. You can probably remove the broken one(s) by drilling into the plug and using an easy-out to remove it.
Or remove the plastic plugs completely and go back to brass drain plugs
Grub54891
Most get over tightened, or cross threaded. Just be careful installing them. Or do as said and replace them with brass.
Capt. Alec
I think it's just that they keep turning it to much but it's just werid because I've had to change them more then one time. My marina had told me you can't put brass fittings in.
Thats funny......... Find a different marina.....seriously.....for over 50 years prior to the plastic fittings brass was used
Ayuh,.... Welcome Aboard,.... The blue Drain plugs are 1/2"- 13 thread,...
Pull the adapter for the blue Drain plugs, 'n just screw a 1/4" pipe thread brass plug into the hole the adapter comes outa,.....
alldodge
Agree, while you cannot install brass plugs directly into the fitting which holds the blue plug do to different thread. You can remove the blue plug and brass fitting, then screw in a brass fitting into the block
QBhoy
Man...a well known issue. I've had the same problems. Even after snapping some previously, I put new ones in less than finger tight and they always seem to magically tighten up more over the season...then you are on it with an adjustable shifting spanner to remove and enevitably breaking one or both sides of the lugs.
They sure look prettier than the brass plugs, but in reality they are just crap....and bloody expensive to replace !
H20Rat
You guys using o-rings on the blue plugs? Not all come with them, but from my experience, the ones without tend to stick themselves tight and will break. The ones with the o-rings seem to last a long time.
tpenfield
If one were to get the stainless steel version, should they be painted blue ? :noidea:
TyeeMan
Master Chief Petty Officer
One could also use a left handed drill bit, , yes they do make them unlike a left handed screw driver. I use left handed drill bits at work to drill out broken screws, , a lot of time the broken screw backs out while I'm drilling it and I don't even have to use the EZ Out.
