slider11111
Thread starter- Joined
- Aug 25, 2017
- 1
I just rebuilt power tilt/trim with new seals. I had the Trim electric motor out and took it to the shop. They said it looks as new and put it back together, I took the boat out and everything worked fine. I decide to run sea foam in it the next day at my house and after running the motor down the motor would go down but not up. It has a single solenoid. I replaced it then the motor would go up but not down? I can jump from the positive side of the solenoid to the green tilt wire and the motor goes down. The same for the Blue wire it will go up so I know the trim works.The tilt trim button on the remote does not work. I just replaced the remote wiring harness thinking maybe there was a short in it. The button does still not work? Where should I look?
