1996 Evinrude 225 wont stay on
Mark 225
Engines turns over starts but at the moment the starter kiks out it dies . I^ve put 12 volt on the yellow/red wire at the powet pack it start and stays on . What could be the problem that the yellow/red isnt suplying the 12 volt to the power pack .
Faztbullet
Check the power coil on stator (orange wires) and if ok bad powerpack
Mark 225
It has a new power pack and triger but i dont understand why the yellow /red wire doenst keep feeding the power pack 12 v
Faztbullet
It only feeds pack when starter is engaged, when engine rpm is fast enough the power coil on stator supplies the voltage to pack.
Mark 225
I have taken the stator on the good motor and put it on the one that doesnt want to start i stil doesnt stay on . Only if i keep the starter turning it will stay on . It has new power pack trigger and stator of the other motor that works perfectly
