I have a 2003 4-stroke 90 HP with an intermittent problem where the motor will not trim when using the switch on the throttle handle. No problems with the switch at the motor. Replaced the down relay a few years ago, this problem has different symptoms. Started in the up direction only. Thought I had a bad switch, but its a sealed switch and looked good. But then it started happening in down direction too. I found a relay module up under the console that I think is the problem. The wires from the switch in the handle go through a 3-way Deutsch connector and then into this module. The module has 3 more wires coming out that go through another Deutsch connector and down to the motor. There is also a ground coming out of the module that ties in with the gauge grounds. The back of it is a rubbery epoxy that has started cracking and I'm thinking moisture is in there. I can feel/hear it clicking when the switch on the throttle is working. If I unplug the connection to the motor, it won't click when using the switch on the handle. Also, when it is unplugged, the switch at the motor still works. I have searched all day for this part. I can't find it. The markings on the side are 586807 and 30 H1C-AB. Where can I find this part or what is it called?
