Water in Power Steering Pump
67Bertram
So. I have a 1983 190HP Merc. 470. Fresh water cooled with power steering. First time out, I notice no power steering. Pop the lid of the pump and find bright pink liquid which seems to be water and ATF. Does this mean that the PS pump cooler is bad? Is this fresh water or sea water? Can I bypass the cooler? Thanks in advance.
alldodge
Most likely, the cooler is the only thing that gets the oil in proximity with water
Depends if you boat in fresh or sea water. The water you boat in is what is getting into the PS pump
Yes, but not advisable. The oil gets hot and needs to be cooled
welcome aboard
+1 on AllDodge's answers
67Bertram
Thank you. Glad that you confirmed that it is sea water and I am not circulating ATF through my engine block. Although sea water in my PS pump can't be good either. Time to pull it off.
oil coolers last many many years with seawater in them.
67Bertram
UPDATE: I pulled off the oil cooler and honestly it seems fine. I pressure tested it the best that I could and it did not have any obvious leaks. I then capped one end of the raw water outlet and filled it with water and nothing seemed to seep into the power steering fluid side. My boat was a basket case and I am starting to think that the water was in the system before I started. Perhaps the engine sat outside for a while.
alldodge
That would be the only other way for it to get in there. Hope everything can be just cleaned up and used
