1977 Evinrude 55hp power loss
Basskicker88
MODEL # 55773D HP: 55 YEAR: 1977
My evinrude loses power when under load. It works fine when on muffs or in idle but as soon as I put it in gear and try to go it acts like it bogs down and won't run. Will not plane runs at very low RPM. I have taken the carbs off and cleaned them very well, new prop, new lower unit oil, new plugs, new fuel lines, new fuel pump/Filter and gaskets, new control cables. Have not done compression check yet or leak test. Is there any simple cheap/free things I can try first before I go that route? Could the exhaust tube be clogged choking the engine with fumes? I know there is probably more info needed but I'm a new boat owner and never had to deal with these problems before.
Thanks,
Brent
Basskicker88
Locating a compression tester tomorrow. Took lower unit off to look at exhaust tube and found a crack in the pipe that the main shaft going from impeller housing to motor. Could that be leaking water into exhaust housing pushing gases back into motor and choking itself out? I'd post pic but for some reason iboats says I'm not authorized to add attachments
