1990 Johnson tilt trim any suggestions
Mrmatthew51890
Okay the trim works going up fine with great pressure, now on the other hand going down it starts to go down then motor stops going down but pump still goes down then I have to push the motor downwards then the motor will fall till it catches then will go down with out my help, tried putting new fluid in as well any suggestions thank you
Joe Reeves
The PTT uses hydraulic pressure to lift the engine... BUT... simply releases pressure until the engine drops to the Trim range. This actually allows the engine to free fall quite a distance.
Check the steering tube as it may be too tight which would not allow the engine to fall.
Mrmatthew51890
Okay I will take a look at that I just did the seals on my steering cylinder and had to take off the support brackets maybe I tighten to much. Also when I do put in the the down range when motor moves with tilt if I hold the motor with a little force motor won't go down the motor just wines. Unless could all be from the steering tube to tight
