Question about the 1971 johnson 50hp short shaft
psinatra
Hello gang, A friend was recently gifted an old runabout with this motor on it. However, it needs a new bottom end. The engine runs fine. So we need to find a parts donor motor.
Knowing that they probably made this motor for a few years in a row, do you guys know what years this thing ran for? And I'm assuming that the evinrude was also the same motor. We need to be able to expand our search.
Thanks and much appreciated!
Sorry, ----ONLY a 71 or 72 model shortshaft 50 hp EVINRUDE / JOHNSON will be a direct bolt it on fit.----And short shaft motors are much more rare than longshaft versions.----Your model number is ??------Your location ?
psinatra
Thanks for your response!
50ES71S
I was a bit surprised to hear that it was a short shaft. I thought those always seemed to be associated with flat bottom craft like dingys and such. The boat is in ontario.
psinatra
here it the boat it's on
psinatra
One more question,
My friend has a lead on the bottom end of a similar model. Basically, it's the same motor but it's the non-saltwater model.
Will this matter for parts swapping? What makes something a "saltwater" model?
No difference. ----Perhaps they meant to say it was never used in salt water.
jimmbo
In that Era, the manufacturers did not offer Salt Water models
