Johnson outboard stutter at full throttle and random quit
TCT15
I have recently bought a 1988 7.5 Hp Johnson outboard. I have taken it out on the lake a few times to fish, and have overall been happy with its performance; however I have noticed two issues:
The first, and most annoying, is that when I open up the motor to full throttle it "kicks/stutters." It almost sounds like car changing gears... the motor doesn't slow down or anything, but it just doesn't sound right and I don't want to damage anything. When I slow down a tad it goes away and runs great. Why is this happening?
The second issue is that the motor will sometimes die (relatively rare) at low to medium speed. Im always able to get it start back up.. but I just want to make sure nothing is seriously wrong with the motor. Why does it sometimes do this?
Thanks for any help!
oldboat1
depends on what you consider serious. I'll guess there is a gearcase issue (worn shift dog), and perhaps some carb or fuel pump issues -- maybe ignition problems. Everything is kind of on the table, given your descriptions. It would be good to start from scratch and see what you have. First step is to replace the impeller, second to do compression and spark tests.
Post a model number to get clear about yr and model/hp -- may not have an '88 motor.
TCT15
I already dug around using the model number and believe it is in fact an '88; however, the model # is J8RCSS and the serial # is E5215897.
I would thnk that it is in fact a 1980 model !!-----It is NOT an 88 model;.
rothfm
Ensign
Bieng new to you, makes sense to do some maint and baseline checks.
The usual compression check is a good idea. A fuel pump rebuild/replace is probably in order as well as an impeller, plug&wires, and a good carb soaking!
I didnt see any mention of maint items bieng done-and these are, if not done already
Afterward you can get into ignition type stuff.
Paddichuck
If it stutters at WOT sometimes it might be either a fuel delivery (as suggested) or ignition issue. Had similar issues with a 1991 Johnson 25 hp, and it was a broken wire in the kill switch assembly intermittently making contact to kill ignition.
TCT15
Considering I don't have extensive knowledge of outboard engines, is replacing anything to do with the fuel delivery or ignition difficult? Also, I may look into the kill switch... that may solve the random quitting problem.
Paddichuck
It is probably most likely to be a fuel issue. I think I'd start with the carb. If you aren't comfortable taking it apart have a mechanic take it apart, check it, and clean it thoroughly.
oldboat1
Would try to find an oem service manual for your motor, using the model number or searching under year (1980). Use parts blow up to service carb: http://www.iboats.com/Carburetor-7-5...iew_id.1536410 Would guess number 24 is the culprit in your case -- high speed jet. Disassemble and soak both halves of carbs (metal parts), after getting a kit. Remove the domed cap at the top before soaking (replacement is in carb kit) -- idle passages. Use a soak and poke method, finishing with carb spray (use plastic nozzle in all openings). Leave the throttle and choke linkages in place for soaking. ("poking" means small wire or monofilament).
Suggest carb cleaning will be a solution to stalling, and might correct the high speed issues. Otherwise, think there may be a gearcase issue based on your description.
ondarvr
From this description there are a few possibilities, and you may be able refine it a little.
A worn out lower unit can bang in and out of gear, so can a poorly adjusted one, but it's typically a bang that can be felt through the boat along with the sound.
​If you have an electrical issue it normally comes and goes like someone is flipping a switch.
A fuel delivery problem is normally a slower and smoother variance in RPMs.
​But from what you said, it almost sounds the prop is ventilating at full throttle, I have no idea what boat this is on, but if it's a little heavy for the motor and you aren't going very fast, the prop can suck air from the surface and the RPMs can jump up and it sounds odd, the speed may not vary much though, and backing off the throttle normalyl brings it back to normal.
TCT15
I think the prop is ventilating at full throttle - what you said describes my problem exactly. The engine is mounted on a 14ft Mirrocraft. Whenever I back off the throttle it always goes back to normal.
Is there any way to fix this, or is it just because of the boat/engine combo?
Short shaft motor on a long shaft transom ?-----Is the transom 20" high ?
