Johnson 115 fast strike bogging out
Mdiddy
Fng
I have tried some old forums but didn't have any luck as it seems some people hadn't posted results or had given up. I didn't want to bring back old forums from the dead.
Symptoms: idles and starts just fine. Runs great at lower rpms and even gets up on plane (19ft deck boat). Once I start to go faster full out or pull a tube it starts to bog or sputter. It will still run and doesn't stop but sputter hard. On occasion it will take off like a bag out of bell then sputter again. When it sputters it's like someone is hitting an on off switch turning the boat back on and off repeatedly. Some days it happened and others it doesnt.
What have I done:
Checked and replaced fuel. All good.
Replaced fuel line and filter.
Cleaned carbs.
Replaced plugs with factory.
Checked compression all around 120.
Any ideas? From some forums I see people replacing stator, power pack, regulator, coil with mixed results.
Would the engine still run if these were in need of replacement? I saw the testing procedure for these and I'm unsure if testing them will show anything.
Gee, I would check the antifsiphon valve in the fuel tank. If they partially clog, the symptoms match yours. Try to pump the fuel primer bulb as you speed up and report back if that fixes it or the bulb collapses.
Mdiddy
Had someone pump the bulb no charge. The bulb feels good.
Mdiddy
J115GLECM
Also Chris1956 I did try an external tank at one point while trouble shooting. Same problem.
jakedaawg
Did you also clean the throttle bodies?
Testing ignition on these can get involved for the typical diyer. Some special tools are needed.
To start I would suggest hooking a timing light up to each plug lead. While having the issue make sure light is flashing evenly on each cylinder.
This is assuming you have done fuel pressure and vacuum tests. All that is spelled out in the factory manual which you will need to purchase to go much farther.
jakedaawg
On second thought, It sounds like it is possibly going into slow mode. Does the warning horn beep once at start up, yes or no? If so, when the problem occurs do you also hear a warning tone? Does this rapid on and off that you experience effectively limit the rpm to 2500?
Mdiddy
Beeps once at start up then not again. Fires right up. The rpms are not limited. They will go higher then it starts to hesitate/cut out but stays running. I could probably post a video of the issue.
I'm hoping the weather is better tomorrow and intend on trying the timing if I get the light and also running checks with a meter on the ignition components.
jakedaawg
k, Back to post #6 will be my suggestion.
