1982 evinrude 60 hp
Stiffler0815
I just bought a 82 evinrude 60hp and somebody cut the engine wire harness out and I need help putting new one in
Joe Reeves
Did you get a receipt from the seller with his right name on it? A cut wiring harness is a dead giveaway to someone in a hurry to get that thing off the boat!
Is the model number still attached to the port transom bracket? What is the model number?
Stiffler0815
No the number is gone. I was going to ask next. So it's stolen then? And I'm in trouble?
Joe Reeves
I don't know if you're in trouble or not... I think not as you obviously are unaware of the possibility that the engine is stolen even with the tell-tale cut wiring harness. You have a choice..... to keep your mouth shut and take a chance of having received stolen goods (if it is indeed stolen)... OR... if the seller can still be located, and you have a signed receipt, visit your local law enforcement department first with your tale, then hopefully you, accompanied, by an officer can visit the seller. I strongly suggest that you do not in any case visit the seller alone!
A suggestion.... look on the powerhead for a quarter sized core plug... looks like a small freeze out plug. It may have the model and serial number imprinted upon it. If so, that would tell us exactly what the engine is... and possibly the numbers would be on the stolen engine list if it is indeed stolen.
