Captain Jeff
Thread starter- Joined
- Jun 15, 2005
- 161
The boat didn't get used last season so it hasn't been run in well over a year. I tried to start it today. First off, the fuel system completely lost its prime while in storage. I disconnected the fuel line from the engine to the bulb and the fuel that poured out was blue with quite a bit of oil in it. It had worked its way into the bulb too as it came out as I primed it. Any reason why oil backfed through the fuel line? (I am still using the VRO)
I noticed the gasket to the vapor separator top was leaking when I squeeze the bulb. Is that the likely reason I couldn't get it started? I am getting good spark.
Obviously the vapor separator cover gasket needs to be replaced. I am planning on replacing the float, needle, and seat while I am at it. Is there anything else I should replace while I am in there? Thank you
