New to me 2011 q5 4.3 mercruiser looking for specs and recommendations
turbodiesel02
So I'm fairly new to boats but not engines,diesel tech by day.just purchased a 2011 Tahoe q5 with a 4.3 mercruiser. Looking to get some insight on what preventive maintaince I should do.engine oil looks new. Any particulars I should check out besides the obvious? What oil should I run in the motor and drive? Any recommendations on filters should I just go to the dealer or are there aftermarket opinions?boat is said to have 70-80 hours on it but who really knows.... thanks in advance
alldodge
Howdy
Have an engine serial number?
Does the boat have an Alpha or Bravo drive?
Like any used car and boat they all should start with a clean baseline. Merc recommends 20w40 oil but many here suggest 15W40 diesel oil due to the added zinc. The outdrive gear lube is Merc high performance 90W and some use synthetic 90W.
Change the oil and gear lube and if you have an Alpha drive, replace the impeller.
While drive is off check engine alignment
Check outdrive boots for wear and cracking
Replace fuel filter
I suggest OEM or WIX which can be found at NAPA (Wix makes napa filters), but can be found cheaper online.
Check the serpentine belt
Load test battery(s)
turbodiesel02
Howdy
Replace fuel filter
Thanks for the input I had planned on running the merc stuff since there was some in the boat I assume that's what it's always had in it. Serial number is 1a629293
Engine oil looks brand new,and drive oil in the res looks new aswell.so I'm sure it was just serviced,the steering cable bellow is showing a little age.how bad are these to change? I found the alignment tool on eBay,should I go ahead and buy it ,a
Steering bellow and a impellar.wheres the best place to buy this stuff?
Rick Stephens
I wait for NAPA to have their annual half price filter sale and buy a case. A buddy of mine gets his from his John Deere dealer at an even better price. A 4.3L Chevy is a 4.3L Chevy. Get good filters and change the oil before parking the boat for the winter and you are golden.
Since my boat only gets 40 or 50 hours a year of service, I use a regular 10-30 non-synthetic on the engine. Lately been Chevron brand from Costco. Since I change it every fall, it looks brand new when I drain it. No need for anything fancier.
I buy Sierra Synthetic marine gear lube for the drive (usually buy it from iBoats). It gets changed with the engine oil and the drive gets left on a stand for the winter. Easier on the bellows if the drive isn't cranked up all winter.
When I winterize my boat I run it on muffs until warm, hook up the vacuum oil suction to the engine then pull all the block and manifold drains and probe the holes with a wire to make sure they are open and fully draining. Then I pull the lower hose off the engine water pump to get the last of the water out. I add no antifreeze. I live in Idaho where it gets below zero. A dry block will not freeze or crack.
I then pull the outdrive. Change its oil on a stand. I do not replace the impeller except every few years seeing as how it, and most probably yours, are Alpha1 Gen2 model. The impeller, once you know if is good, will last for a number of years.
Make sure everything is put away perfect and your boat will not take damage in the winter. Changing all the oil before parking it will get any water contamination out before storage.
Enjoy. No reason to purchase OEM Mercruiser for maintenance stuff. Many replacement parts - you bet! OEM is the only way with a lot of them. Ask away here and you'll get the straight answer.
Rick
alldodge
Its is always good to have an alignment bar. Having it on hand when the drive is removed becomes a good time for the quick check.
Don't use how the lube looks in the bottle as how the lube is in the drive. Over time the lube in the bottle gets thick and will clog the tube going to the drive. The lube in the bottle should be changed every few changes in the drive. If the drive is installed when the drive is filled the bottle will be filled at the same time. Lube is pumped in from the bottom drain hole up.
In most cases the steering cable last a very long time. Its not hard to change but I would suggest unless your finding some issue with steering, just wait
Here is the parts break down for your motor
http://www.mercruiserparts.com/4-3l-mpi-alpha-bravo-1a030370-thru-1a0
