1972 Johnson 50HP electric shift problem
DanNeedsHelpWithBoat
Hi,
So I had just rebuilt the transom on my 1952 fiberglass runabout, i loaded the boat up with some friends and hit the river for a little sunset cruise. The engine started up great, we had gone about 6 miles up the river then there was a loud sound from the engine and we lost power. The motor never stopped running, I could throttle up in both forward and reverse but the propeller would not spin. Luckily we got a tow to a launch ramp that was only about 300 yards away. The lower unit had brand new oil in it, the engine didnt seem like it had over heated at all, there was no hiccups in how the engine sounded while running.
Any idea what could have caused this? or what I should look for? I'm waiting for a friend to have time to pull off the lower unit but I imagine it could be a few things such as broken shaft, shift linkage breaking or becoming unseated, bad water pump.
thanks,
Dan
jbuote
I have a 71' 50hp...
​Still new to me, but there really isn't any shift linkages to break. It's Hydro-Electric, so it has shift solenoids that direct the lower unit oil to shift the gears...
​Did you use Type C gear oil? Make sure the gear oil states it's for electric shift..
​I hear some Type C's aren't made for electric shift... :noidea:
​Don't know too much about the insides of the lower unit other than that yet..
​Another thing to look for:
Maybe you hit something and spun the prop hub?
Just some thoughts to start off with.
The Experienced folks will be able to guide better than I can.. LOL
​Hope it helps even if just a little..
thanks for the response.
yeah, it had type C oil in it. I drained the gear oil and it was still clean, no water, no metal shaving or anything.
Im hoping it's something simple like a spun hub.
Yeah, i guess i meant the hydro-electric equivalent of shift linkages.
I just pulled the propeller, started the motor and throttled up in F and R...the shaft the prop mounts on was not spinning at all. looks like we need to pull the lower unit and investigate further.
F_R
Could be the shifter switch in the remote control. However, probability is something busted, like the drive shaft.
No Title
so i dropped the lower unit and there was a good amount of SAND!!! around the water pump....so thats a problem...but can someone tell me where i disconnect the electric shift wires? I haven't been able to fully drop it because they are still connected. is the disconnection up on the top end? I thought it would be around here...should i cut away the black rubber/housing around the wires...is the disconnection point there?
Joe Reeves
The default setting of the lower unit if the electric went out is for the unit to be locked in forward gear mechanically. It sounds like the driveshaft sheared... hellava job!
No Title
So I found the shift wires...they were covered in electrical tape. Turns out the knife connectors were not really there either and someone just seemed to solder the ends together. Hopefully I can clean these up and put bullet connectors or something between them. Also, Yup! the drive shaft totally sheered. does just old age and wear cause this? how do I make sure this doesn't happen again after I put a new one in.
oldboat1
Slide the tubing away from the knife connectors, and disconnect the wires.
jimmbo
At least the piece fell out of the crankshaft.
oldboat... looking at the pic, it looks like one of the knife connecter is there and the rest butchered
sodak_nakeddog
Not to highjack your thread but can you tell me how you got your lower to drop? I have a 71 50h and I want to change my water pump but I can't get it to drop at all I took out these 6 bolts 4 on lower unit 1 on cavatation plate and one behind the plate. What am I missing?
oldboat1
Yeah, not pretty, jimmbo. Afraid PO's pics hit while I was typing -- not sure what to say about that one.
Short shaft or long shaft ?----Only a lower unit from a 71 or 72 model will be a direct swap.----Classic fatigue failure usually caused by time / bent exhaust housing.
F_R
As unlikely as it seems, yes the gearcase and exhaust housings do get bent. That causes flexing of the shaft with every revolution.
Hmmm, those were the 6 i took out too and it just sort of started to separate on its own due to gravity. Not sure if the 71s have another bolt somewhere or not.
good luck
F_R
Have you applied any gentle persuasion at all? There is a big rubber seal at the inner exhaust tube, and the rubber seal on the water pump. In addition, if it has never been apart, the seam was sealed at the factory with a gasket-sealant material (or even if done since, a lot of people reseal the seam, which is OK practice.
ohio stan
Get the wiring straightened out first(sealed). A wire that grounded at the wrong time might have snapped your shaft, It tried tio change gears at the wrong time.
thegipper
I am no expert but on my 1970 60hp, the drive shaft bearing/housing were pretty worn. It had about a 1/32" of play because the bearing were so worn. You may want to check that too, if the drive shaft has play in it because the bearing is worn, my guess that could cause stress on the drive shaft also.
It was also the reason why I was getting water in the LU. The seals in the driveshaft bearing housing were shot because the shaft was beating up the seals.
