I just finished rebuilding a 24' pontoon boat and put a new to me 1982 Evinrude 115 on it. Boat originally had a 1978 115 that blew last October. I picked this engine up as a replacement once I finished replacing the floor.
Took it out and ran it last week. Engine starts and runs fine...but seemed to lack power compared to the other engine. Turning the same prop as before...14 1/2" X 11 Degree. WOT was pushing the boat 12 mph at 2,800 rpm. I also put a new transom on the boat which sets the engine back a little further than prior, if that makes any difference.
Started diagnosing on the hose once I returned home. Started by pulling all plugs and checking compression one cylinder at a time...All 4 are +/- 110lbs. I then started it and noticed that while idling pulling plug wires on either (or both) of starboard cylinders (1 & 3 maybe?) made no difference in engine sound. Pulling either plug wire on port side would choke down and even stall engine. Got out my spark tester and all 4 wires from the coils jump a 7/16 gap.
Since then I have rebuilt carbs (even though I don't believe this is the prob..with boat on trailer and engine in gear at WOT, I lightly dusted across carb throats with cleaner to see if engine would pick up...made no difference..I also held hand in front of carb with engine idling and fuel would come out). I have switched the power packs from one side to the other..I have switched the plugs (all brand new) from one side to the other. All made no difference.
Another thing interesting, is that I took an inductive timing light and hooked up pos and neg. Hooked clamp up across plug wires and only bottom two cylinders would make light flash.
Only thing I haven't checked is replacing plug wires.
Is there anything I'm missing here? Perhaps engine is indeed running fine, but when pulling plug wires while idling shouldn't all cylinders make a difference? Even if the boat is heavy and won't move fast, shouldn't that engine be able to turn the heck out of an 11 degree prop?
Any help is greatly appreciated, as I'm stumped!
Bryant
Bryant
