Hello O wise ones......
Hope some of you can decipher this....sorry if it's a little vague.
So I recently purchased a twin to my grandfathers FD-11. I wanted to have two or more of them, because I just do,. I also picked up a parts FD-11 at an auction for 10 bucks a few years back. Prolly just needs coils/points/impeller and carb cleaned. But I bought it to sit in the boat house in case I ever needed parts.
Over the winter I've rebuilt both of them, as in the basics. Carbs, impellers, coils-points-condenser, fuel lines ... and all around spit and polish. My grandfathers engin went well and runs like a top as it always has. The new purchase FD-11 has been fighting me. And I need to say that this engin was torn down to pistons by a father and 14 year old son as a project. The son wants to be an engineer and the father thought this would be a good project, I liked that. However, I well knew what I may be in for, when I saw that they had cut the gaskets themselves through out the power head, with a paper thin type gasket material. I'll add that I liked this kid, and told him if he ever wanted the engin back, to give me a call and it's his for the same price. .....they needed to sell it to fund their second project, a dirt bike rebuild....but I could tell he was pretty attached to this old 57.
On this engin, I decided to pull the power head for a better look see....
I'll back up a bit.....bought it with tank for $250. It looked like it may be a low hour engin due to gear case fin paint was intact. And although the whole unit had been cleaned, the original paint from top to bottom was in very very good shape. The kid stated they had only tank run the engin for a sort time, and his Dad nodded his head in agreement.
I didn't have much time to really look hard at the engin as I was on my way home to Cinci after working on our cabin for 3 months deep in the north woods of the UP of Michigan. Also picked up a 57 Starcraft Ski Champ in Petoskey earlier in the day for a hundred bucks. Bottom looked like it had never been on the beach.
So when I pulled the head and the lower unit, I noticed a fairly good layer of black older looking oil/tar covering its insides. I was able to easily wipe off what I could reach. I don't have a compression checker, but when pulling the engin through, it sure seems to have good compression. And ran well today on the lake, after tuning, with equally good power and top end as Ol'reliable, maybe better.
So anywho, I bought new gaskets for the power head, inspected the head as best as I could, torqued all nuts and screws and reassembled the FD-11. Set the needles to factory, and it fired right up in the tank. I ran it for maybe 3-5 mins and shut it down. After I took it out of the tank, I noticed black oil leaking out of the area of the two rear power head screws. It was about an inch wide, and ran down to the impeller discharge. Note, the power head screws and nuts were torqued and then re-torqued an hour later. I used permatex #2 on the power head gaskets, lightly.
Today, I Lake tested it. And after fine tuning the carb, it ran perfectly. Low speed idle was really sweet, and top end, smooth as silk. Brought it back to the ramp after a few hours and there was the black oil stream again......
I've run my grandfathers FD-11 at our cabin in the U.P. of MICHIGAN since I was 5 and each year since for a total of 58 years. Never noticed a black oily stream coming down the aft of the lower unit. Maybe it has from time to time, but I'm a fairly detail oriented guy and never saw one. And it didn't leak black oil two days ago when I Lake tested it.
So, O wise ones, and much more knowledgeable than me.....what's up with the black oil ...??.....my novice guess.....this engin was run with a heavy fuel/oil mix....like 16-1 for years. Maybe the remnants of straight 30 weight from years gone bye. And it will clean itself out after I run 24-1 for a while. ???? But I just want to be sure it's not something more sinister....
Thanks fellas,
Dave
Thanks fellas,
Dave
