Gimbal housing install
Jbasham
Looking for the drawings/manual for the mercruiser gimbal housing installation, like the bolt pattern and hole sizes for the transom. I have an OMC Cobra but the pattern is the same. I've seen it posted before but can't find it anywhere. Thanks
Jbasham
The pattern
Thank you. The factory install manual shows the keyhole cutout with dimensions. I really just need the hole sizes for the 6 mounting studs and the steering arm clearance notch dimensions...
JASinIL2006
This says Volvo Penta, but the Merc cutout is the same.
  • SX Transom shield cutout template.pdf
Ayuh,..... 1/2" drilled holes,....
Donno the angle for holesaw drillin' the tiller arm spaces,....
I just use a rotary file on a die-grinder, 'n cut to fit,....
