Trim Tab Issue
Redhot
I apologize if this is not in the correct forum and I did try and search for the answer to no avail, but I do believe I read on how to trouble shoot this issue on here, so here goes. Both trim tabs will fully extend in the down position. After about 5 minutes the stbd tab will begin to retract and in 10 minutes is in the full up position. The cylinder is not leaking. I swapped the lines at the pump and the same problem happened, but now on the port side. So my issue is in the pump on the one side. What do I need to be looking for. I am told there may be a valve or something in there................??? Thoughts? Thanks for the help.
- RH
alldodge
Its probably the valve seat is damaged. On two other forums there is a guy called Tabman and he works at Bennet. Send him an email and he can get you the parts to fix
Tmcgow@bennetttrimtabs.com
Thalasso
If the trim tabs are retracting by themselves then most likely the valve seats in the solenoids or the plungers are damaged.
If something other than ATF was used in the system it can damage the plungers and cause them to bypass.
Tabmanhelp@gmail.com
Tabman
iboats.com Partner
- RH
Do you know what brand Trim Tabs?
The other posters are correct, likely a damaged valve seat.
If they are Bennett, we can send you new valve seats and instructions how to change them, no charge. Just send me your name and address in a private message or at Tabmanhelp@gmail.com
Tom
Bennett Marine
alldodge
Tom
Bennett Marine
Cool didn't know you were here Tom, will try to remember
Redhot
Thanks for all of the replies. I just saw them! They are Bennett tabs Tabman I will be sending you an email. Thank you.
Redhot
Big shout out to Tabman and the Bennett team. I received my valve seats yesterday and will be putting them in today. What a great CS team over there. It is much appreciated, Sir.
Tabman
iboats.com Partner
Glad to hear they did the trick! We are delighted to be of help. Tom Bennett Marine
Tabman
iboats.com Partner
Tom Bennett Marine
