weatherlight210
Thread starter- Joined
- Jun 24, 2017
- 3
I have a 1966 Johnson 40 hp Super Seahorse rkl-28b, and I've been looking all over for instructions on how to replace it's water pump impeller. Which I found here: http://boatinfo.no/lib/evinrude/manuals/1956-1970johnsonevinrude.html#/310 , The problem is the electromatic shift wires pass through the upper water pump housing, and it seems to be stuck. I can't pull the wire through. There's these rib like protrusions along the wires length which are caught in the hole.
Could you guys give me some tips or help on getting the two separated? I don't want to accidentally wreck my shifting while fixing this pump.
I also have to fix up the carburetor, but am having trouble finding the parts or kits. If you could be so kind to point me in the right direction for them, that would be great too. Also, related to the lower unit, I out in 80w90 oil into the gearcase, and the manual says to put in Type C oil. Is there much of a difference? I have no problem changing it out, but I'd also like to not make the mistake of using the completely wrong thing.
Thanks for any help! I did try to find this info here, but nothing I read seemed to relate specifically to my issues. Thanks!
