cfauvel
- Aug 16, 2005
- 645
Bosunsmate,
this thread maybe what I experienced....SeaHorse's response here speaks to what I observed
http://forums.iboats.com/forum/engi...es-when-closing-the-gas?p=6319321#post6319321
Probably need to bump up the RPM for my no-oil test
re-reading WernerF's post on his problem
http://forums.iboats.com/forum/engi.../552261-vro2-question-about-no-oil-flow-alarm
we see that he was working with an older 3 wire VRO, which as SeaHorse pointed out MAY have a different circuit to rule out false alarms.
So the expected horn at 1365 revolutions at idle (I think we are back to having 6 as the multiplier) may NOT be that simple and require a little more speed, I don't know....
Given that we may be back to a 6 multiplier and the 1365 revolutions to sound the alarm...at 2000 rpm the horn should sound in 41 seconds
(1365/2000 = ..6825.....68% of 60 seconds = 40.95 seconds)
How long can the fuel in the bowls last at 2000 rpm, that is a question.
So my next test will be to run at 2000 rpm and see if indeed the horn sounds in 41 seconds. (remember I was testing at 1100 rpm). I will warm up the engine...run(on premix) with out the oil line in and wait for horn (3 min and 40 seconds...now we know there is NO residual oil in the chamber)...shut the motor off to reset the counter, then re-run the motor at 2000 rpm with a stop watch.
I don't have a test wheel so can run it up to near WOT and don't feel like doing these tests on the water
