Temp Gauge & Sender unit 2000 Johnson 225
GFabry
Good morning,
Recently purchased a used boat, a TEMP gauge is installed but no TEMP sender unit is not connected. Not sure where to hook it up, a few threaded holed are there but not going into the cylinder. Anyone has a picture of where to screw it in? Is drilling required? Thank you
bob johnson
most times it is in a head, or both heads.... I would GUESS that year has a1/8th PIPE threaded hole on each e\head for a sender unit.... if not many guys used a Z bar sender unit that was sandwiched under a head BOLT
GFabry
Thank you, do you see the whole in the pictures above by any chance?
Would the threaded hope need to be drilled at the bottom or should already been done and a bolt should be covering it?
bob johnson
I see 2 little X's.....no pictures
