rfeiler007
Thread starter- Joined
- Jun 16, 2017
- 15
My phone isn't allowing me to upload the pic right now. I pulled the prop off, and the hub appears intact and inside the prop itself
since my last post, I hit a rock on the river and took out my lower unit. I have replaced it with a used one with new gears, water pump, and a new prop & prop hub. After all that, I took it out and it STILL does the same thing. So now I have ruled out gears and prop hub. I've been reading up and researching more into this issue, and "fuel pump" keeps coming up. I have the VRO style with the oil line plugged and the alarms disconnected (somebody before me did this). I do not want to replace the whole thing, as I am very comfortable with mixing my gas/oil-and $$ is also a bit of an issue since i had to replace the lower unit. I have researched enough to have found a fuel pump to replace the VRO pump. What are your thoughts on this?But,has it slipped from its original position? A spun hub won't necessarily appear all torn up. If you are unsure of whether it has slipped , while you have the prop off, mark the hub at the point where it presses into the prop barrel and make another mark on the prop barrel at the same location and see if it moves after another water test.
Yes it might could be the stator crapping out at higher rpms. It happens.Put a timing light on each cylinder when it's acting up and look for black spots. If you have them you have an ignition problem. Not fuel.
They always sound great on muffs. Don't let em fool ya ...I ask because it won't do it on muffs....
Ain't that the truth.They always sound great on muffs. Don't let em fool ya ...
