1984 johnson overheating issues
bf15
My 1984 johnson is overheating, IM trying to determine if on this engine if the peehole would still output water even if the thermostat is bad.
the model number is e50belcrm. When i took it out, it basically was steam coming out of the peehole. I put a new propeller on it about 1-2 years ago, but have only used the boat maybe 4 times since then, So im hoping this is the thermostat being locked up. I read online that some boats the thermostat would block off the peehole if it does not open where others it comes out the peehole constantly even if its locked up.
Also, is there anyway to identify if you have a wedge style vs pin style propeller? I was going to order a new waterpump kit but it ask which of the 2 types do you have.
Joe Reeves
Wedge or pin style propeller?? I've been in this line since 1960 and never heard of that. Your engine has a splined propeller.
First, check the compression to see if you might have a failing head gasket... that would cause overheating. If the compression is as it should be, start out by replacing the water pump assembly.
ob
I think the OP must have meant impeller instead of propeller.
bf15
Yes sorry impeller. I ordered a new thermostat and gaskets needed to replace that.
Looked through my johnson book but not instructions in it on doing the compression test on these. Whats involved in that? Also how could i tell if there are any blockages in the water system? I was thinking about blowing air through the pee hole but where would i feel the air coming out at if i did that?
89Aluma
I doubt you have a blockage, detach the lower unit make sure it's in neutral, stick it in a bucket of water make sure the water level as close to the top as possible. Wrap some masking tape around the splines of the driveshaft attach a drill to the driveshaft and turning it the same direction the engine spins should be clock wise but double check just in case. Start slow water should start coming out of the tube pretty quick. If that gives you no water your impeller is bad. If the impeller isn't bad I would pull the thermostat out and run it and see if it overheats. If it doesn't overheat your thermostat was the issue if it still overheats I would be worried about blockages or head gaskets then
juno pierrat
how do you know it over heating? alarm?
yes, water should come out the peehole if thermostat was stuck, if no water and your sure the peehole, water line and 90 degree elbow on the water passage cover is clear then its the water pump. also go ahead a order a head gasket, its really a lot easier to remove the head to get to the thermostat then getting to the bottom bolts on the water jacket, also then you really get to see all the water passages around the head.
bf15
Its the alarm going off, alarm starts about 5 minutes after turning on, and motor sounds sluggish compared to earlier this summer when i started it up.
I found this diagram, looking at it looks like all the thermostat requires to replace it is removal of the head cover. IS this correct?
Also, is any one knows what the torque numbers are for those bolts it will help, I looked in my book and even though its got the 2 cylinder diagram, it seems to only list clearances for the head, not torque on the 2 stroke engines.
Im pretty sure the 90 degree elbow is cleaned out, I guess i can stick a pipe cleaner down in it. to know for sure.
ALso just wondering how easy is it to burn up one of the impellers. I rememberd about 2 weeks ago i was testing something else on it and the ear muff's popped off, it did not over heat then, but could the ear muff's popping off cause the impeller to melt?
interalian
Yes, running without water will quickly destroy the impeller.
