1986 evinrude 90 v4 issue
Travis2329
Hi everyone, first post here. I have a 1986 evinrude v4 90hp on the back of a 1979 mark twain v sonic 170.
My motor is having a WOT issue, it just started today and im not sure where to start looking to resolve the issue. When i was out today my motor would run up to 4200rpm (normally 5200 max rpm) and would bog down And wouldnt go past 4400 rpm. The carbs were rebuilt a month ago and ran with no issues until now. Im not sure where to start, im thinking maybe a jet is plugged but i just rebuilt the carbs. Maybe a dying coil or powerpack? Also the vro was removed and i mix 50:1. Any help is appreciated
History of breaking piston rings.-------So the trouble shooting on those starts with a compression test.---------If that is good you check for spark that jumps a gap of 7/16" on all leads.----------Those are the " no money spent " checks to do.
I like to see 120 + psi on my gauge.----------Your gauge and technique may show a different number
Travis2329
Ok so i tested compression and got
115 on 1,
112 on 2,
113, on 3,
110 on 4
Also the spark tester i have doesnt show a spark arcing across but i touched it once while cranking and it shocked the sailor outa me, so i need to find another way to test the spark i guess
cfauvel
get another spark tester.....a spark could shock the heck out of you BUT not be sufficient for combustion.
I would check for loose magnets under the flywheel., then stator values for both OHMs and voltage whilst using a DVA Adapter.
Travis2329
So upon doing some testing i found that cylinders 1 and 3 are not getting spark, power is coming from the stator and all the coils have continuity. So im thinking the power pack died
Travis2329
I disconnected the black/yellow wire coming from the powerpack. That changed its runability from no spark to plenty of spark, so i have a bad stop circuit in the powerpack, in which case it's junk as far as i can tell. I will put the pin back in and swap sides to test again in the am.
Fed
No Travis it means your black/yellow wire is short circuiting to ground somewhere.
Red plug, wiring harness, key switch, kill switch, would be the main suspects.
interalian
Wouldn't that kill spark on both packs?
Fed
So now we have a mystery.
A short to ground on the suspect pack black/yellow but that black/yellow is not connected to the good pack black/yellow?
It's hard to get past disconnecting the suspect black/yellow gives spark yet reconnecting the black/yellow (which is supposed to be isolated) kills the spark.
Maybe time to find a twin pack circuit diagram to make sure we haven't missed anything, I only have a single pack diagram here.
Travis2329
Now may be a good time to also mention that i had an issue where when i would turn the key off on the last few trips the engine would keep idling, but not a good idle for 5-10 seconds until it stalled ( like running on 2 pistons), which if the stop circut in the power pack is malfunctioning, it could let those 2 cylinders keep running after its been turned off or it wouldnt let them run at all which is now the case. Havent gotten a chance to swap power packs yet, when i do ill let you guys know, thanks for the help so far.
Travis2329
Okay here's an update I swapped the powerpack to the other side of the engine and the issue followed and I move the good powerpack to the side that had the issue originally and I had plenty of spark. so it seems that the culprit is in fact the powerpack
Fed
Yet if you disconnect the black/yellow wire (that goes no where) from the so called bad power pack then it makes good spark?
Something's not adding up right?
Travis2329
The black and yellow wire tells the power pack whether or not it should be sending power to the coils via a diode based on ignition switch position, if this diode fails it can result in an issue where the pack cant tell if it should be delivering power to the coils or not. Hence the issue of running with the key off and no spark while trying to start the motor.
Fed
I checked your wiring diagram on the Max Rules website and it doesn't show the diode, if you have a genuine manual for your motor that shows it then I'd naturally believe the manual.
cfauvel
I believe the diode he is referring to, would be inside the power pack, thus would not show up in the normal electrical diagram (as they wouldn't be displaying the internals of a power pack) .....certainly a mystery....the fact that the problem switched sides, I would have to agree that indeed the power pack is the culprit...
jakedaawg
Yes, replace pack, common for spark to come up. Isolating blk/yel. Manual states to then test blk/yel for fault to gnd. Test key/kill switch then replace pack if it passes those. Or it may be in my notes from class 20 odd years ago or the cdi book, but yes, replace pack.
Fed
I read it (post #16) as the type with the diode in series with the black/yellow cfauvel and the motor doesn't have one.
The S.L.O.W. system didn't come until at least after 1988.
Have you got a model number Travis?
Connecting the black/yellow to the bad power pack does also connect it to the good power pack so maybe there's something going on there.
It would be interesting to try for spark on the 'bad' one with the black/yellow disconnected from the 'good' one.
